2-10's vs 1-12in Sub
  • 3
Darius2004
Hello, I've been reading the forum for a while a just joined. I searched but couldn't find any solid answers to my question.
My system consist of:
Nakamichi Head Unit
PolkAudio db6500 seperates [FRONT]
PolkAudio db650 2-way with Xover [REAR]
2 - Kicker KX600.4 amps [TRUNK]
1 - Kicker C12 Free-Air 12" Sub
2 - Xtant A1040 10" subs in a Q-Logic Box
Right now I have the Kicker sub installed but I just bought the xtant subs and the Qlogic box. I'm worried that I may lose some depth going with the smaller speaker but I've been told that 2-10's will hit harder and cleaner than 1-12
Could you guys please lend your expert advise?
PS - One Kicker Amp is power the cabin speakers and the other will power the 2 subs.
Any and all help is appreciated. Thanks in advance.
cleaner has nothing to do with it, it is really a point of do you want more volume ? if you not that worried about blowing the doors off the single 12 is fine
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
825
I can go as big as i want really,. But my max area i want to dedicate to it is, 36w x 15t x 15d. Single 12 dvc 4ohm wired to 2ohm with 800watts...
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
183
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
345
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
436
Darius2004
Darius2004
California
Darius2004
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
