2 10inch RE Audio SE PRO's
cleansoundzz
2 10 inch RE Audio SE PRO subwoofers. These are identical to the original RE Audio SE subwoofers. They are both dual 2 ohm versions. They come in the original boxes with the instructions and everything else. They were purchased from an authorized dealer and picked up directly from the RE warehouse.
Mounting Depth - 6.4 inch
Mounting Hole Diameter - 9.3 inch
Overall Diameter - 11 inch
Bolt Hole Circle - 10.1 inch
Motor Width - 7.3 inch
Motor Depth - 3.4 inch
Basket Depth - 2.94 inch
Displacement - 0.14 cu. ft.
Weight - 21 lbs.
T/S Parameters
10"
Electrical Q Value -Qes: 0.46
Mechanical Q Value -Qms: 4.4
Total speaker Q Value -Qts: 0.42
Free Air Resonance -Fs: 26.6 Hz
Equivalent Compliance -Vas: 31 liters
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency -SPL 1W/1m: 83.2 dB SPL
Effective Piston Area -Sd: 310 cm^2
DC Resistance -Re: 2.8 ohm
Nominal Impedance -Znom: Dual 2 or 4 ohm
Thermal power Handling -Pe: 600 W
Force Factor -Bl: 17.7
Barely used 9/10 immaculate condition
$250 shipped. No trades just cash only. Will only be shipped within the United States
I am interested and ready to buy, ive sent you a message requesting payment information. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
cleansoundzz
cleansoundzz
Buena Park
cleansoundzz
