Oldschool kenwood excelon
cal
kenWOOD KDC-X969
Description/Condition:
used , has some light wear ,small cut on atenna plastic but not on wire and the plastic that holds the trim ring is cracked ,i had it glued but took apart to show in pics . unit was top of the line in 2006 and has 1 yr total of use if that. besides what is listed in description and seen in pics, no other damage is present and is in fully working condition. please see pics. reason for selling is i found an apine ive been wanting to try .
SPECS :
designed to put the latest technology at your beck and call. Operation is simple — soft key controls change function according to the mode you've selected (no confusing array of buttons), while the rotary control affords easy adjustment of system functions.
The 3D MASK™ motorized, detachable faceplate motors open to reveal the simple control panel and a high-resolution, fine-dot, 3-D multicolor display. If the stunning graphics aren't enough, you can create your own images and movies to download into your receiver. power down, and the face motors up to display a plain, black panel; or you can detach the face and take it with you.
The KDC-X969 plays CD-Rs and CD-RWs loaded with MP3 and Windows Media Audio (WMA) files, displaying all title information on its oversized, multicolor display. A single disc can hold over 10 hours of music, so you can store an entire CD collection on a few discs — and Kenwood's folder/file search gives you super-fast access to the track you want!
The 4-way MOSFET amplifier (22 watts RMS/50 peak) provides the brawn, while System Q EX (with its 6 EQ curves, speaker size matching, and 3-band parametric EQ) shapes the sound to perfection. Kenwood also offers the 3-way sound enhancement of SRS WOW™ — you can raise the soundstage (useful if your speakers are mounted low in your doors), focus the stereo image, and improve bass response with this remarkable processor.
Three sets of 5-volt preamp outputs provide powerful signal to your outboard amplifiers; you can even shut off the receiver's built-in amp to maximize performance. To get the most out of your speaker system, System E's+ includes adjustable high-pass crossovers for the front and rear speaker and preamp outputs, with a low-pass filter and phase adjustment for the subwoofer preamp outputs.
Interested in more entertainment options? The KDC-X969 will control a Kenwood CD changer, Music Keg digital media player, or SIRIUS Satellite Radio tuner (SIRIUS subscription and antenna also required). You can connect the audio signal from a video game, DVD player, or VCR to the receiver's auxiliary input. Or, upgrade your AM/FM reception by adding Kenwood's HD Radio tuner (when that technology becomes available).
A wireless remote control is included for your convenience and driving safety, and Kenwood backs this receiver with a 2-year warranty. Impressive performance, elegant appearance, and the latest technology — the Kenwood Excelon KDC-X969 receiver is here to serve you!
Details:
3D MASK motorized, detachable face
fold-out control panel with rotary control
fine-dot 3-D multicolor FL display
customizable, full-motion graphics
plays CD-Rs and CD-R/Ws
CD text
plays WMA and MP3 files stored on CD-R and CD-RW
displays MP3 text and WMA titles
CR-2 tuner
18 FM/6 AM presets
SIRIUS Satellite Radio controls (SIRIUS Radio subscription, tuner, and antenna required to receive the satellite radio signal) — service is available only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories
HD Radio-ready
SRS WOW sound enhancements (raises the soundstage, improves imaging, and strengthens bass)
Bass Management System (lets you adjust the bass boost on compatible Excelon amplifiers)
dual zone audio control
Speaker Setting function — optimizes receiver output based on the size and type of your speakers
System Q EX Sound Control (6 EQ presets, speaker size matching, and 3-band parametric EQ)
System E's+ Advanced Crossover
5-volt front/rear/subwoofer preamp outputs
amp muting circuit — turning off the built-in amp improves the quality of the preamp output signal
CD/MD changer controls — add a Kenwood changer or Music Keg to your receiver order, and save $$ with Crutchfield's package discount
zero-bit mute circuitry eliminates receiver output when no signal is present (between CD tracks, for example)
auxiliary input
wireless remote
clock
22 watts RMS/50 peak x 4 channels
CD frequency response 10-20,000 Hz
CD signal-to-noise ratio 105 dB
FM sensitivity 9.3 dBf
2-year warranty
for ipods 3rd generation or older one can use the adapter kca-ip500 on the cd charger of the h.u. or if its a newer version all you need is a mic to rca jack and plud right into the aux rca
150 shipped con u.s.
the unit sounds great , i replace a pioneer i had back then because the flip motot went out and i liked the kenwood better . also the unit has a very nice eq inside so you can tailor the sound to your needs.
cal
cal
cal
