brooksi
i have narrowed it down to 2 amps that are in my price range. They are an Ultimate TA2600-II and an Earthquake TNT600. They are not very expensive. People have told me to get a JBL 600.1 but im not a huge fan of JBL and i have read too many mixed reviews. Here are the specs from the two amps can you please help me pick one that would push the 2 10'' Kicker Comp Vr's the subs are 300 rms and 600 watt peak. If you know of any other amp that is better than these 2 (besides a JBL 600.1) and is under $160 please list it or tell me which of these amps would the better job
Earthquake Specs:
Maximum output power: 600Watts ·Output Power: 65Watts RMSx4 into 4 Ohms ·Bridged Output Power (2Ch): 200Watts RMSx2 ·into 4 Ohms ·Distortion: 0.015% THD ·Frequency Response: 10Hz-35kHz +/- 1.5 dB ·Signal To Noise: 104 dB ·High Level Input: 3V-7V ·Low Level Input: 200mV-4V ·Size(WxHxD): 8 1/2" x 2" x 12"
Ultimate Specs:
Amplifier Type: 2-channel
RMS Power: 180W x 2
Bridged RMS Power: 430W x 1
THD at Rated RMS Power:
Speaker Level Inputs: Yes
Preamp Outputs: No
Built-In Crossovers: HP/LP
Bass Boost: 0 or 12dB
Frequency Response: 10-30,000 Hz
Channel Separation: n/a
Signal to Noise Ratio: >100 dB
Fuse Rating: 2 x 20 amps
Earthquake Specs:
Ultimate Specs:
RMS Power: 180W x 2
Preamp Outputs: No
