1st sub install need help please
cordoba
hi all i just got myself a small sub with built in amp Active 12" Enclosure (tube design) EN-AT1120 product page HERE i'm trying to get it connected to a jvc KD-G421 i would be very greatfull for any help in getting this connected and working //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif thanks
It says on the product page of the sub that it comes with all of the wiring and instructions in the package. I would do what it shows there.
thanks for the reply i have followed the instructions but getting no sound out of the sub at all the light is green on the sub so it is getting power
Well that is a different issue all together. Can you tell us what you have done so far and include some pics so we can help further?
conneting it in work at the mo won't be able to up pictures till 2mo //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif anyway the red cable connected to the + on the battery, rca cables are in the back of the radio, blue wire is connected to blue wire on the radio and brown wire connected to chassie all wires are in a connection block for the fusion sub+amp
There might be two different blue wires on that head unit. Make sure it is labeled REM and not ANT.
it's connected to the plain blue wire in the head unit have i connected it to the wrong one?
sorry my mistake the wire is purple
You can verify if that is the issue by using a small jump wire from the POS+ wire going to the sub amp to the REM input on the amp. That will force the amp on. That is just a temp solution to verify that it works. Do not use that as a permanent solution.
hi again is the the right blue wire?
cordoba
cordoba
dublin
cordoba
