1st MMATS amplifier Model 2075 Linear Power styling Circuit breaker reset
Huge2na
MMATS 2075 Amplifier
Good condition, clean internals, works great
$150 shipped anywhere in the lower 48 states
Spec:
2x75W @ 4Ohms (2x100W Pure RMS Tested)
1x300W @ 4Ohms Bridged (1x450W Pure RMS Tested)
1x600W @ 2Ohms Bridged (1x900W Pure RMS Tested)
Do not run it at 2 ohm mono it will pop the circuit breaker , it was and is not designed to run 2 ohm mono!
I agree I believe it will only be 2 ohm stable in stereo, Most likely only doubling the rating. Also it is a clean amp (sound quality wise), I don't have the detailed specs, MMATS did not even have them. This was a 8 legged Unicorn to them. I also think this predates the Depth Charge Series amplifiers. It's an awesome amp.
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I honestly think that stock locations work great for 90% of the people. With today's DSPs, you can move the listening position anywhere you wish...
996
Huge2na
Huge2na
Reading PA
Huge2na
