1awg welding cable 15ft
basshead7890
Al
1. Product:
SGX 1 awg cable
2. Specs:
little more then 15ft
3. Description/Condition:
4. Price: :
40 shipped
5. Pictures:
** DO NOT DELETE ANYTHING BELOW THIS LINE OR THREAD WILL BE DELETED **
This message is automatically inserted in all classified threads.
Please be advised, all buyers and sellers should satisfy themselves that the other party is genuine by providing the following via PM to each other after negotiations are complete and prior to dispatching goods and making payment:
1) Telephone number. Call the number back at a unspecified time and make sure that it is the person's correct phone number.
2) Name and address including postal code
3) Valid e-mail address. Send an e-mail requesting a response to information about the deal being made.
DO NOT proceed with a deal until you are completely satisfied with all details being correct. It's in your best interest to check out these details yourself.
If transaction was completed on CACO, please use iTrader to record feedback.
Potential buyers/seller should check iTrader feedback also before continuing transaction.
is this ofc
It's all copper
1 AWG SGX INSULATED AUTOMOTIVE XLPE INSULATED WIRE WITH A 125C TO -40C TEMP RATING AND HAS 7X37/25 STRANDS OF BARE COPPER FOR EXCELLENT FLEXIBILITY, NOMINAL OD IS 0.46 WALL THICKNESS 0.065 SGX PER J1127. VOLTAGE SAE J1127 THIS WIRE IS INTENDED FOR USE AT A NOMINAL SYSTEM VOLTAGE OF 60 VOLTS DC OR LESS IN SURFACE VEHICLE ELECTRICAL SYSTEMS. TEMPERATURE CLASS RATING IS 125C. THE TEMPERATURE CLASS RATING IS DEFINED BY SAE AS A CLASS DESIGNATION BASED ON THE RETENTION OF MECHANICAL PROPERTIES AFTER 168 HOURS OF AGING AT 30C ABOVE THE TEMPERATURE CLASS RATING.
bump
One piece is 15' and the other is 20"
100% copper and it's cheaper then car audio wire
sorry not to troll im just curious.
i know copper is very conductive but welding wire can it be flexible? also would it be better conductivity than a good audio power wire?
sorry not to troll im just curious.i know copper is very conductive but welding wire can it be flexible? also would it be better conductivity than a good audio power wire?
Not as flexible as car audio, the strands are larger and it should be the same.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
526
https://www.ebay.com/itm/263364485734?mkcid=1&mkrid=711-53200-19255-0&siteid=0&customid=link&campid=5335951755&toolid=20001&mkevt=1
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Oem cables are readily available for most vehicles. Check rockauto. Anything less will be a future headache.
10
basshead7890
basshead7890
Al
basshead7890
    Apr 28, 2024
    Apr 28, 2024
