Crossfire 3way active crossover
d77543020
Rating: 87.5%
7 1 0
Item(s) for Sale: crossfire cfx 23
Item(s) Description/Condition: like new
text 2093903075 for a faster response
Price: 60 shipped
Does it have subsonic filter??
who cares.....you should be running this to a 3 way active front stage. use the head unit's hpf at like 80z to give the midbass section a combined band pass filtering. for 60 bucks you wont find a better pre amp that will do this. steal for sure for anyone putting together a semi decent or better 3 way front.
I've been wanting to do a 3 way active front, but I'm not real clear on how this unit would accomplish this. If my understanding is correct, I would HPF the rear on my HU at 80hz and set the subwoofer LPF on the crossover to 150 and feed the mid bass? then set the band pass section on the crossover to feed the midrange, run the tweeters off the front out of the crossover and keep my subs running from the HU as they are now? Is this correct? And what does the parallel switch do? Would 80hz to 150hz be enough for midbass?
heres how it would work,you use your front pre out and run it to this mans crossover.
you need to cross your tweets over from 4-5Khz.
run your mids band pass
but looks like the low pass section doesn't meet up with the mid section...
in my set up I run
the tweeters from 4500 and up
mid range 4500-900
midbass 900-50
unless your headunit is set up for 3 way,it really wont do it..
d77543020
d77543020
stockton ca
BassAddictJ
