1999 Rango, a little revamping
A little product for the Rango //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
This is a Tri-coat 6 hour process
Sealer is applied and awaits HOK Tri-coat. Took care of that nasty rust and cleaned up the rockers. We are changing up the base to HOK and using a Shimerin' with pearl for the seven layer clear. Three layers will be laid, wet sand, then the final four, wet sand then buff, and finally polish.
Time for paint:
Here is the paint right out of the can:
Don't worry, the clear coat we had mixed really turned out well. Here is the fresh lay:
Since I am having split duels ran behind the rear tires there is no need for this little exhaust cut out, unfortunately I had to make both side match since the OE bumper cover is molded to have the cut out.
Wheels, front bumper, and headlights are now installed. Still need to get the rear spoiler on and replace the radiator and A/C condenser bracket.
I performed a "cut through" in the hid-away compartment in the rear. Yes it hits hard.
12 grade cold rolled stainless welded to make the enclosure carrier:
The enclosure. Sealed, 1" thick high density.
Perfect fit....with some hammers:
Box welded to chassis:
FIBERGLASS!!!!! To seal it up tight, and some carpet over it:
And no one knows the wiser. Plus it leaves a lot of room that most enclosures take up.
SPLAudioHz
SPLAudioHz
Indiana
SPLAudioHz
