1997 Dodge Dakota Build
Kikazz74
whats up guys? ive recently moved over here from SMD and thought i should post my build up.
Equipment list from begining to end.
HU:
JVC KD-R320
Sony CDX-GT270MP
Clarion CZ500
Sub Amp:
Hifonics BRZ 1700.1D
Speaker Amp:
JL Audio G6600 6 Channel
Wiring:
Kicker 1/0 for power and ground
Xscorpion flat 1/0 for Big 3
Kicker 12ga for sub
Sub:
Fi Audio BL 18 d2 fully loaded
Speakers:
Kicker KS65 Coaxials in doors and rear
Tweeters:
currently alpines
soon to be Rockford Fosgate Power Series silk domes in keep_hope_alive tweeter spheres
carpeted amp rack
From or made by keep_hope_alive
onto pics
ports
tools to sand ports
painting the box with my special mix
gear for the first round
what could this be?!?!
i think its my sub!
next to a size 16 shoe
im 6'4" and roughly 270lbs as a comparison
as of now that is the finished project minus a tweeter change and some tuning. it has been a great chance to learn some things good and bad. i cant explain how much help kha was to me. it would not have been done without him. hearing his car gave me a better appreciation for what sq really is. he inspired me to step this up a bit.
so please feel free to comment or leave me questions guys. ill be around to answer them.
thank you
Cody C.
i forgot you posted this.
a few of the photos i took:
we used some rubber mounts (about 1/4" thick each) to gain space behind the amp rack and also absorb vibrations.
what this is:
we wanted to essentially tap the 1/0 power for the sub amp to feed the 6-channel. so this is a dual 1/0 connector with a short section of wire to a fuse holder to feed the G6600. once it was secure, i wrapped it with self-fusing silicone tape (rated to 1000V per layer).
there are front and rear coaxial drivers. but some more highs were needed since those speakers are muffled due to location. i put in some tweeter spheres for the short term, and have them running through the passive crossovers shown below. eventually, a decent active crossover would let us just run active and defeat the tweets in the doors.
I have the CT Sounds 150.4 and two 2000.1. Pretty clean and solid amps for more than a year of use. I wouldnt expect the CT Sounds 80.4 to be any...
10
Amazon has Infinity Reference 9630 Harmon refurbs on sale for $120 bucks. Compared these to several other brands and using an old NVX 2"/SB...
954
Hello all of you, unfortuanally as mentioned before it isn’t possible to get fader with this setup: Pioneer radio 4 way output and a factory amp...
26
in advance i already a have a sub skar zvx hooked to a 1500 watt ab mono so take into account there will be a sub may or may not change out the...
Kikazz74
Kikazz74
Quad Cities, IL
keep_hope_alive
    May 10, 2024
3toneEYZ
    May 10, 2024
