1996 mustang box plans?
ajspellm
i will need some box plans for a 1996 for mustang gt. it has the mach 460 in it but i am going to take that out and replace everything. i am going to put my 12" kicker l7 into it. the trunk has a slight slop in it so i dont know how to get a correct measurement but will try. i want the box to be ported.
I have a 2000 mustang and all I had to do is tack the mach 460 system out and remove the latch panel for the back seets and cut 1in of metle out of the way up to the bult holes for the panel and i got a box that is 32 13 20 to fit in with know problem and when you bolt the panel back on there is no way to get the box out to steel it the onely prob is the is no rear fill I wont be able to heare it over my L7 so who cares i hoped this helped out
Seriously man.. learn to spell
max dim. for a mustang of that body style is 32Wx30Dx12.5H and the mach 460 tray HAS to hbe out for it to fit..... also.... you half to fold down the back seats undo the mtal thing lining the trunk openeing and bend it all the way down and put it in that way.... its also a lot easier if you take out one of the front seats.
did you put the mach 460 back in or did you replace the speakers with something else?
I have no rear fill and I had to cut the car after i undid the mtal thing lining the trunk openeing up to the bolt holes and you can get a 32Wx30Dx13.5H box in with no problem with the Volume Calculator at the12volt.com that is 6.03646 cubic feet and with the box you have is 5.53342 cubic feet
ajspellm
ajspellm
Omaha, NE
spljim
