p3fosgate-impal
Banned
Can U Swap A 1.8 Engine With A 2.0 Turbo Engine Is The Bolt Pattern Any Different And Will I Need A New Transmission???
Honestly.. It's going to be cheaper + soooo much easier to just start with a Turbo DSM to begin with. You'll have to find a 6-bolt 4G63T with the FULL harness. You can use a 7-bolt, but I'd stay clear of them as they tend to crankwalk quite often( and it's just more work). Then you'll need to route a new exhaust system and find a sufficient fuel supply. You can use the same ******.Can U Swap A 1.8 Engine With A 2.0 Turbo Engine Is The Bolt Pattern Any Different And Will I Need A New Transmission???
SO YOU SUGGEST FINDING A ECLIPSE WITH A 2.0 AND BUILDING OFF THAT INSTEAD OF SWAPING ENGINES?Honestly.. It's going to be cheaper + soooo much easier to just start with a Turbo DSM to begin with. You'll have to find a 6-bolt 4G63T with the FULL harness. You can use a 7-bolt, but I'd stay clear of them as they tend to crankwalk quite often( and it's just more work). Then you'll need to route a new exhaust system and find a sufficient fuel supply. You can use the same ******.
-Bill-
