18" SSD box size
If you were to buy a Kicker, Rockford, or Alpine subwoofer, are you always going to follow the manufacturer box recommendations?
This is 2 Fi 15s with like 2.5-2.6 cubes each.
That didn't come across like I meant it. I don't think they know what box size it needs, but they should. I don't understand the technical side to how a smaller box is louder than a larger box. I like getting technical //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
It just depends on the amount of power that you have available and what the sub can thermally and mechanically handle. Bigger box = more efficient, but limits the mechanical power handling of the sub. Generally more power is > more box volume, as far as attempting to gain deebeez, so if the sub can thermally handle more power than you're giving it, and in its current box is able to be pushed to it's mechanical limits, then by all means make a smaller box in order to feed it more power.
If you can't make the sub max out with X amount of power, a smaller box isn't going to gain you anything 99% of the time...maybe some trunk space.
Buck
little alien on campus
Buck
Inside of a pyramid
RAM_Designs
