Sold 160amp Alt
TooLowTooGo
2Low2Go
160 amp alt here forsale
has all new parts in it
selling it to get airbags for truck:)
n e way i tested this out on my own system before taking everything out to put everything in there boxes to sell
*all done with a 8second burp to get full numbers*
idle
1 amp at 2ohms - 12.6volts
2 amps straped at 2ohms - 11.8
1200RPM's
1 amp at 2ohms - 13.6
2 amps straped at 2ohms - 13.1
1500RPM's
1 amp at 2ohms - 13.7
2000RPM's
1amp at 2ohms - 13.7
each had its own 200amp breaker and 2/0 power wire and grounds from battery
1/0 wire from alt to bat n bat ground to frame
so these numbers will vary on how ur set up and what amp(s) u are using
these numbers are done with a stock battery and power acoustik A3000DB's
was this with all your accessories on? ie. lights, heater/ac... yadda?... and is this the small case gm or the large?..?
fits in my blazer so im guessing small case
and the numbers were done with no lights or heater/ac on
not many ppl will compete with there AC full blast...the only time i ever used ac was to lower the temature in my truck before i competed...never used it while i was up
fits in my blazer so im guessing small caseand the numbers were done with no lights or heater/ac on
well i'm not looking for it for comp uses.. i'm looking real life... i have a 105 i think now on my chevy and **** i draw almost into the read going full tilt ... and if i have my ac on ****!!... ... ... but i'm running 3 amps... and one of those happens to be a current hungry 2 channel!!... hmm i'll have to look around i want to do it right the first time and i don't know if the 160 is enough...
heh, i can stall my burb from so much amp draw
front and rear a/c on full
all window motors on
headlights on...
causes it to go under 11V, into the red zone
Not even playing anything
TooLowTooGo
2Low2Go
TooLowTooGo
Jersey
TooLowTooGo
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
