Sold 1600 Hifonics Brutus Amplifier *Brand New in Box*
$Rogue$
I have a brand new in box 1600 Watt Hifonics Brutus Amplifer
It normally costs $500, I'm letting mine go for $299.95
Never Been Used So It Still has Factory Warranty!! //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
Call or text (925)336-9154
Brutus: The King of D-Super
When it comes to class D monoblock amplifiers, Brutus amplifiers are truly the king of D class. Brutus BXI amps are considered some of the best amplifiers in the world and the new Super-D Class Brutus amplifiers reinforce that. The D-Class digital chip-set technology produces extremely efficient, low temperature, and a high amplification system resulting in a smooth digital to analog conversion with low distortion. The amplifiers stable at 4, 2, and 1 Ohm(s). All in all, that means that the amp will produce more output with less stress on the car's battery and charging system.
•Brutus BXI Single-Channel Monoblock Super-D Class Car Amplifier
•RMS Power Rating:
◦4 ohms: 550 watts x 1 chan.
◦2 ohms: 1100 watts x 1 chan.
◦1 ohm: 1600 watts x 1 chan.
•MOSFET Power supply
•Super D-Class amplifier relies on a super-speed enhanced chip-set to produce higher current capacities and more precise digital to analog conversions
•Wired remote bass level control included
•Power and Protection LED indicators
•Built-in system diagnostics offer protection of DC, Speaker short, terminal, and overload
•Tuned Bass EQ (0-10 dB bass boost at 45 Hz)
•Dampening factor: >250
•Single-channel monoblock channel operation
•1-Ohm stable
•Phase shift: 0-180 degrees
•Preamp RCA outputs
•Input level control: 0.04V - 18V
•Balanced line input for MX accessories and line drivers
•Heavy duty aluminum alloy heatsink for extreme heat dissipation
•RCA level inputs
•Screw terminals
•Variable low-pass filter (35-250 Hz, 24 dB/octave)
•Subsonic Filter (15-35 Hz at 24 dB)
•Frequency response: 35-250 Hz
•Dimensions: 14-1/4"L x 9-1/2"W x 2-1/2"H
$Rogue$
$Rogue$
Livermore, CA
Walled_Taurus
