1500+ @ 2ohms Clarion DPX
ciaonzo
TheContinental
Clarion DPX115511. Makes 850 @ 4 and 1550 @ 2. Not recommended @ 1 ohm.
This is, for all intents and purposes, brand new. I used it for one summer so there is not a mark on it anywhere except for the evidence of being mounted with screws, condition is flawless all around. It's a Robert Zeff design (Zapco/Arc), class G/H so it offers efficiency similar to class D amps but with much improved sound quality because the output sections still operates similar to class A/B. It definitely makes the power, no question there. It also has the handy feature of being able to adjust to your line level inputs, whether they are low volt or high volt. Posted a gut pic below that I found online (thanks, TREETOP) but I will get pics of mine up for you guys, no worries.
Also, a link to the crunchfeel page for this amplifier. --> https://www.crutchfield.com/S-1xcJq9M1AxJ/p_020DPX1155/Clarion-DPX11551.html
1550W x 1 into 2 Ohms, @ 1.0% THD
850W x 1 into 4 Ohms, @ 1.0% THD
Input Voltage Sensing
Precise Frequency Selector -24dB / Oct. Low Pass Crossover, 30-230Hz
Adjustable Subsonic Filter, 10-80Hz
Variable Bass Boost; 0-15dB @ 30-125Hz
Gold Plated Connectors; RCA/ Speaker/ Power
Dimensions 16-3/4" x 10-1/8" x 2-3/8"
Requires 1/0 gauge wiring and an external 200 amp fuse.
$265 shipped, CONUS.
CONUS only, please.
Glws. I have what I guess is the newer version of this one. The one that can do 1500 at 2 and 1 ohm.
Sent from my LG-H910 using Tapatalk
Nice, how do you like it? I always wondered how this would do @ 1 ohm but didn't want to risk it.
ciaonzo
TheContinental
ciaonzo
WI
ciaonzo
