1500-2000 watts
Audiopipe AP1500D, get a hold of R/T Pimp on here, they run under $250, very very solid 1500wrms all day long at 1ohm, and they are .5ohms stable! Sexy and very effecient solid power!
well first of all you have to understand how amps work. Take the fuse size that is on the amp and multiply it by how many volts you are running from you battery. So lets say that you has an 80watt fuse and you are running 12 volts (which is what most single battery cars run) so take 80X12= 960 this is you ture max power. than take 75% of that and this is you efficientcy. the amps that say they are 4000Watts are not reallly. physics wont allow it. use this when you are looking for amps!
I have an fusion nv-am25001 for sale that needs a small fix that does 2200 at 1 ohm 12.5 volts and 2600-2800 at .5 ohm. extremely efficient. I kept the voltage above 12.5 at full tilt with only an extra battery. it can be run .5 ohm daily. I think that the max current draw is only something like 218 amps or something like that.http://www.caraudio.com/forum/showthread.php?t=364072
they can be found new for just a little above what you are wanting to spend though
According to Crutchfield, those JLs won;t fit in your dash, can't see why, just what it says on their site. it says those JL's won;t fit in the...
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
515
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
790
Well, there is always a bypass that can be McGuyvered. So next time you want to tackle that task, post it. We can help.
All you need. I've been running these for years in 3 different vehicles. https://www.amazon.com/dp/B01BL57JO2/?tag=caraudiocom-20
nuboot
nuboot
lawton, ok
allout13
