1500-2000 watts
well first of all you have to understand how amps work. Take the fuse size that is on the amp and multiply it by how many volts you are running from you battery. So lets say that you has an 80watt fuse and you are running 12 volts (which is what most single battery cars run) so take 80X12= 960 this is you ture max power. than take 75% of that and this is you efficientcy. the amps that say they are 4000Watts are not reallly. physics wont allow it. use this when you are looking for amps!
I have an fusion nv-am25001 for sale that needs a small fix that does 2200 at 1 ohm 12.5 volts and 2600-2800 at .5 ohm. extremely efficient. I kept the voltage above 12.5 at full tilt with only an extra battery. it can be run .5 ohm daily. I think that the max current draw is only something like 218 amps or something like that.http://www.caraudio.com/forum/showthread.php?t=364072
they can be found new for just a little above what you are wanting to spend though
nuboot
nuboot
lawton, ok
allout13
