15" Nightshade
think a nightshade 15 will be able to take a 3000d daily on music w/ gains obviously set conservitively?
The stock suspension is too soft for me to be comfortable saying that is okay. I can build re-cones for you later one that will be much more comfortable with that power level.
to the tread starter3.5 cubes tuned to 35hz with 90square inch port will be a great starting point for u
80
Thanks, would this be for SPL or more of a daily setup? Im willing to make two boxes and just switch them out when it comes to competition time
that would be a decently loud daily box....but for spl i would do 5cubes tuned 2 or 3 hz below ur incar frequency with a 85square inch port...and resin the inside of the box and use 3 6inch aeroports
u should be very loud
80
that would be a decently loud daily box....but for spl i would do 5cubes tuned 2 or 3 hz below ur incar frequency with a 85square inch port...and resin the inside of the box and use 3 6inch aeroportsu should be very loud
80
I cant fit 5 cubes...2006 Honda Civic LX coupe..around 4cubes is the most I can do before I have a chance at plugging the airway from the trunk to the cabin. How do you tune the aeroports? I know different lengths but how do you know what length is what Hz? Im good with the slot port, not use to the the aeroported because I dont have a program for it. I just use the RE Enclosure Calculator. And can I find resin at any hardware store like home depot and lowes? Its a lacquer right?
80
You have your box sizes backwards. Big box daily and small box for spl.
If you want a good all around box go with 3ft net and two 4" or one 6" port. Tuning is up to you but for daily I don't like anything higher than 36hz & prefer low tuning around 32-33hz.
Isn't 3 cubes too small though??? I was thinking before displacement, about 4 cubes tuned to 32 Hz for daily and about 3.5 cubes, maybe a little less tuned to 37or 38Hz for SPL
Mattd0344
Mattd0344
Colorado
sundownz
