15" FI Q Vented Enclosure?
Qbenjamin
Tell me what you guys think about this enclosure? These plans were done by Squeak12. My max dimensions were: 37(W) 17.5(H) 13-15"(D). Tuned to 31HZ @ 3.1CUF.
The pieces that need to be cut are as follows:
Top: 36x15
Bottom: 36x15
Side 1: 15x15
Side 2: 14.25x15
Front: 32x15
Back: 34.5x15
Port 1: 11x15
Port 2: 17.5x15
Why the **** are you posting someone's plans on the forum? That's basically having them give out a free design to everyone. If you were unsure if it's okay, then why didn't you ask him? Stupid '07s.
And the only thing I see wrong is to move the cutout further to the right so you don't run into the port when mounting. Besides that (which isn't even a problem), it looks fine since I'm not going to check his work since it's just that...his work.
I may be wrong but isn't it better to have the woofer in the center of the front baffle instead of on either side?
...Not really, in fact with non subwoofers you want to avoid centering the speaker as much as possible.
PV Audio, I paid for this plan, so it's mine and free to post to whoever I want. I wouldn't have posted it if I wasn't questioning it a bit myself.
It not far off, I get the follow doing the calcs:
Net Volume: 2.94 cu/ft
Tuning Freq: 30.26 Hz
That is using Fi's driver displacment of .19 cu/ft
but I did see a panel lenght problem... I'll give you a hint look at the face. 32" is missing the wood thickness.
You are a complete idiot. He made the plan for you, now you just went and posted it so everyone can use his work for free. Good job. Do you have any idea how much detail goes into a box design? Apparently not, seeing as you just ****ed over his business.
Indeed.... You ever finish those crossover? //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
Designing them again right now. Will have graphs soon!
LOL, you are a moron, he has no business. I just found somebody that said yes, he could do one. He never said that I couldn't post anything. Before you start insulting someone how about you find out everything that is going on first. He put all of his work into it............Blah blah blah. This guy did the box in less than 10 mins with box builer 5.0.
Ya know PVAUDIO, for someone that has 15,468 posts, your still not too bright if you think that one box plan is going to apply to every vehicle.......OMG you just ****ed over his business. STFU!!!
//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif I make at LEAST 4 designs a week, and have made over 150 different ones since I started, and not ONCE has anyone posted one of my plans unless it was me. It's called business courtesy.
Qbenjamin
Qbenjamin
Braavos
PV Audio
