15" brahma need a ported box
  • 2
atx
Does any one know the specs for a 15" brahma, will someone build me a ported box for a brahma 15 running a 1200x1 amp. IT will be going in a car trunk. Music will range from rock to rap. Want it to hit really hard and be loud.
adire will give you spec sheets when you order. Even if you just email the techs there and ask they should answer that for you. ported or not? Depends on what yuo want. You want good sound quality go with a sealed box. If you want louder bass then go with a ported box. As far as box building, sorry maybe someone else can help you.
It was a system from 2 vehicles ago. The enclosure was rock solid. Had a P9 combo to deal with whatever equalization was going to be required.
Can't go wrong with either sub, but the Brahmas seem to have a little more "oomph" down low. Obviously both subs do fine down low, but the...
106
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
94
432
atx
atx
Nor*Cal
spencerS
    May 12, 2024
Brendon Jenness
    May 11, 2024
