145.8 Legal with my Budget setup
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif allow the inside of your car where the sub is to really get cold as in temperature.You will notice minor meter number bumps. As it gets hotter inside where the sub is you will notice a minor lower number.
Anyways nice number, it helps to have a closed off car like a santa fe.
yea i know cooler ususally can gain you alittle, however to cold can be bad and it was like 27 deg. im sure thats not good on your equipment. it makes subs stiff and can actually mess up the sub if pounded with out warming up alittle
This is not always true. ONLY the meter will tell you for sure.
I hear this a lot but I have yet to see actual evidence.
yea its hear-say for me to. ive heard people say their surrounds seperated because of the cold but idk
good for you, i need to try to get more out of mine but i have just 1 12" i'm not even sure what my real number is, but i think you got the best bump for the price //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
thanks, i think i can get alittle more out it. once it gets warmer, ill probably pull it out and make either a fiberglassed port with flares or get a port made and should gain some. Also will fiberglass the inside of the box to smooth it out should gain alittle and my voltage probably played some in it to. My voltage drops quite a bit so im sure if i can get that up some ill probably gain a some there.
cool, getting ready to add a batt. to mine but still stock alt //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
my alts stock also. i dont have big 3 done either because my alt is under my engine and is a pain to get to //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
bgowdy
Heroes are remembered, but legends never die
bgowdy
Campbellsville, Ky
bgowdy
