130 amp alternator not enough
travd27
I have a 130amp alternator right with about a 1700-1800 watt system it holds up fine with the optima yellow top under the hood. I plan on upgrading my system to 2 mtx 1501d and soundstreams VGA500.4. should be around 3000-3500 watts. I talked to Ohio generator today and the guy told me if i'm cruising around under 2000rpms or at a stop light i may have turn it down. this is using a 200amp alternator and a second yellow top battery. Does anyone know of any alternators that put up high numbers at idle
someone on here just bought a 275 amp alternator from excessive amperage... it does 150 amps at IDLE. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
i had real bad dimming with only 1000w on a 130 amp, **** you moe, now my alt feels inferior except for the 275amps at 2500rpm //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Ohio Generator does some insane amps @ idle. They build an alternator that does 190 at idle and 210 at 1200rpm for my explorer.
I talked to them also but to get a quote on a price I had to go through a car audio dealer. whats that all about???
travd27
travd27
HAWAII
travd27
