mattmillme
What amps would you look at if you're wanting 12,000 watts rms or more on 14 volts? I would like to have 15,000 but could go as high as 18,000. I would prefer to keep my system voltage in the 14's, but may be convinced to go with more voltage. I need a single amp as I have PLENTY of room for length(probably 50ish inches), a good amount for width(about 14~16[possibly more]), but not much for height(probably 4 inches max, prefer less). Most of the amps that I can think of are extremely long, but don't have enough power. I don't think with my vehicle there will be any way to mount more than one amp and still do the build as I would like. I don't think mounting two smaller amps on my trunk lid would be a very good idea due to vibrations. Oh, BTW I plan on slightly overpowering 6 ZV4 10's(hopefully 2500 rms to each, but am open to as low as 2000 and as high as 3000). I may go with 4 NS V3 12's or 15's as well(hadn't thought about box design enough), but more than likely not. The systems is for everyday stuff more or less, so it can't get too hot when under a 1/2 to 3/4 load for a few hours straight(long drives, ~6 hours nonstop). I would also like to take it to car audio shows and demo it for a couple hours straight at a time at basically full tilt, no competitions though. I will probably have 3 alternators(one with wattage in the low to mid 200's for everyday, and 2 in the mid 300's range when needed) to power it and 4 batteries(Kinetiks, 24 or 3800's), no capacitors.
This is an off question, but with having 12-18K watts in subs and probably 2-3K rms in components and tweeters; do you think the electrical I had planned will be even close to enough for the system to perform well at high volumes? I don't think I would have any more room for more electrical, maybe one more alternator at most.
