1200-1500 rms @ 1 ohm
ed nine.1 195 brand new
never worked with ED, hows the quality and sound and power they put out, over rated or under?
aww man, when do they plan to have them in stock? looking for a RIGHT NOW sorta amp not one i gotta wait for
Well if you wanted to spend more for a better quality amp I got a Crossfire xp1400 been benched at 1700rms at 1ohm. 250.00 shipped. it is in perfect condition comes with orignal box and gain knob.
1700 @ 1 ohm might be too much, i was hoping to not give a full 750 to each so 1500 was the most i wanted to see from an amp
called them and they said they just got them in stock on wend and should ship out today or by monday, they are great amps look at the reviews, 5 year warranty, there rated at 12.5 volts and with 14 can put 1500 plus
WHat kind of car? My truck would insta die ... my battery dial that tells me the volts like drops nearly to bottom when in idleing and i only have 1200 watts..
Scion xB with a HC1800 in the front and HC800 backup.
I want that car so bad... it just looks like a sub machine... so much air space and room in there.. at Formula D some guy had a XB with 4 15's in like a bongo drum box idk what its called it was sick though
I would put the full range to ch.3&4, and low pass on ch.5&6. The 6.1200 line out should be full range unless it has a dedicated x-over. In that...
It should be fine as long as you're not looking to upgrade in the future.
  • Poll
Its not a huge upgrade and I'd argue you likely couldn't tell the difference.
  • Locked
I have one if you are still looking
BeAlLsTaR13
BeAlLsTaR13
New York
05fronty
    May 12, 2024
Brendon Jenness
    May 11, 2024
