12" woofer for 2000 watts
8" might just be as good as it gets for a sub that'll take that kind of power. I'd get that DD if i were you
Why would an 8" be as good as it gets? Lots of high powered 12s out there without huge mounting depths
---------- Post added at 03:59 PM ---------- Previous post was at 03:58 PM ----------
Ok I could make you a ring spacer for the baffle
Assume just adding space to the outside of the box where the sub mounts?
i guess my wording was wrong, i shouldve said "id try to make the 8" mounting depth work to run the DD, as it would be my choice if possible."
Im in a similar situation too, as i drive a single cab. But i'm able to fit around 10" mounting depth
Yes. Just a ring to space the sub out 3/4"
i guess my wording was wrong, i shouldve said "id try to make the 8" mounting depth work to run the DD, as it would be my choice if possible."Im in a similar situation too, as i drive a single cab. But i'm able to fit around 10" mounting depth
What truck?
DaytonLax14
DaytonLax14
Ohio
jboy2015
michigan born
    May 14, 2026
michigan born
    May 14, 2026
