12" 1000w RMS @ 1ohm Sub?
DJ Riggz
don't ride no white horse
I'm looking for a 12" sub that can handle about 800-1000w rms @ 1ohm. So maybe a DVC 2ohm? I'm also looking for a 70/30% sq/spl ratio. I need it to work in a small space as a I have an extended cab truck, so nothing more then 1.25-1.75 cubes sealed.
Any and all input is greatly appreciated!
Thanks
i dont no ur budget but i think the Adire brahma 12" is exactly what u want...its REALL loud and sounds real good......plus it works great in a 1.25cubie sealled just putt al little less power to it nd ur good
so you dont think the brahma would be underpowered? i see the rms on the brahma is 1600w. i'll only be able to push about 1000w rms.
Thats fine. It will be as if your volume is always turned down a little. If your going sealed...which i believe you said you are, make the box as big as u can go so it takes less watts to push it to its max.
^^^^id leave it 1.25
and also i went to adire yesterday and cris said that usually 6-700 is good enuff in that sized sealed....but hey...try whatever u want....if it was me id go with what the guy that makes em says....
cool thanks for your input. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif i'm guessing the cheapest place to pick one up is direct from adireaudio.com?
DJ Riggz
DJ Riggz
Roswell, GA
denim
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
