10's for SQ around 500w rms each?
I'm fairly sure it is just 500 x 1 @ ohm.
So that opens a large door in what you may want. If you go new Cadence and SSA both have some great subs that work well on low power. If you go used then there are a ton of options.
A budget would be needed to be able to suggest different options though.
So..you're amp is putting out 500w @ 1 ohm, so you're going to want subs that are rated @ 250w a piece? Or will it give each sub 500w?
I have a DLS A6, so it's rated for 1200w at 1ohm, so would that be 600 rms at 0.5 ohms to each sub? I haven't been "in the game" for a while, but my current setup is wired correctly as both subs are DVC.
Any ways, my budget would probably be around $100/sub? Not necessarily looking for brand new, used would suffice, just don't know what specifically to look for. I think around $250 for both subs is around a decent price?
Well how is your electrical cuz your amp has been known to be a current hog...
Big 3 is done, running 2 batteries, yellowtops, I was running 2 12''s IDQ's fine with Pheonix Gold RSD's. I think I can get around 80-90A from my alt?
you have no idea what that amp really is do you? That amp is something I'd run. as for subs you already know you like the 12's so I'd just use the same as 10's
WoofersEtc.com - IDQ10V3.D4 - Image Dynamics 10" IDQ Version 3 Subwoofer
do not use their recommended box though get one designed around your car.
Any other companies? I'm looking to go used to cut down on costs and I wouldn't mind a different company.
Sonic has the Image Dynamics ID10 D4 V.3 for 139, so I guess I can get 2 of those?
Would 2 10's still be better than just keeping one of my 12's?
PuZo
PuZo
Toronto, Canada
zako
