1000+ Watt Amplifiers
Keenwood KAC-8101D
400Wrms bridged
200Wrms x 1 @ 2 ohms
1000 watts maximum peak power (4 ohms bridged)
1 ohm stable
$255
Pretty good amp for the price pushes my CM3's real good.
does the phoenix gold octane 1500 really push 1500 at 2 ohms cause i heard alot of peeps say that thats the peak and not rms but on the amp describtion it says 1500x2ohms but also says max power so wondering about that!!! hit me up somone
hey SS3079 that is not private cowboy......the private the drill instructer is yelling at is private Joker......private cowboy is shorter than the Drill instructer....
i just used the very cheap one..i used rodek 1000 watts...brighted mono block 1000 4 2 ohm...i just brought it bout $120 us only..hehehe...
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
The JD does ~800 watts@ 3 Ohms so I assume there would be no noticeable difference.
806
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
  • Locked
Do you have any pics with user name and date or is this at a local garage sale?????????????????
Gauntlet
bulletproof
Gauntlet
Cleveland, Ohio
Phlipbak
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
