1000+ Watt Amplifiers
Power Output 787 watts RMS x 1 channel at 4 ohms
and ≤ 1% THD + N
1114 watts RMS x 1 channel at 2 ohms,
14.4V supply and ≤ 1% THD + N
Signal-to-Noise Ratio 70dBa (reference 1 watt into 4 ohms)
Dynamic Power 1339 watts at 2 ohms
Effective Damping Factor 6.348 at 4 ohms
Frequency Response (–3dB) 10Hz - 302Hz
Maximum Input Signal 6.1V
Maximum Sensitivity 140mV
Output Regulation .14dB at 4 ohms
Dimensions (W x H X D)
Main Unit 18-11/16" x 12-5/16" x 2-3/8"
MSRP U.S. $ $549.95
I have an Alpine MRD-1001 and i love it. Great Solid Clean Powerfull Bass. Awesome bang for the buck. Only problem was that it took me forever to navigate my way through the all digital settings, figure out how they effected the sound, and finally get it all tuned. This amp has just about every setting you can think of and pretty much gives you full control over every aspect of sound adjustment. Ive had probly 6 different systems over the years, and this is my best one ever!
How about the JBL Crown GTi amps
A3000GTI
1670 Watts RMS x 2 channels at 4 ohms @14.4v
3129 Watts RMS x 1 channel at 4 ohms @ 14.4v
3078 Watts RMS x 1 channel at 1 ohm @ 14.4v
A6000GTI
2600 Watts RMS x 2 channels at 4 ohms
and ≤ 1%THD+N
8110 Watts RMS x 1 channel at 4 ohms,
14.4V supply and ≤ 1%THD+N
7400 Watts RMS x 1 channel at 1 ohm,
hi im new here. ive been looking at the new clarion dpx1200.1 which has 1500w max and 1200w rms @1ohm, to power my 2 12' fusion powerplants. its seems like a pretty good amp
This amp isn't available yet, but the flagship of the new Cadence Daytona line has
5000W RMS @ 1 OHM
3000W RMS @ 2 OHM
400W @ 4 OHM competition power
The model number is DCA5000. The amp is 28" x 9.5" x 3.5" and **** sexy. It should retail somewhere in the low $3000 range.
Gauntlet
bulletproof
Gauntlet
Cleveland, Ohio
Phlipbak
