1000 watt amp (550@4)-(1000@2), 2 ohm sub can i just leave it at 2
I have a new kicker cxa1200.1 amp and the new mono kicker amps advertise themselves to be 1 ohm stable. But the owners manual says it will still only put out the same 1200 watts rms at one ohm as it does for two ohm. But only 600 watts rms at 4 ohm.
Sounds perfect. The new Taramps Smart3 puts out 3K at one ohm and 2 ohm at 12.6v. That is a good thing.
not to thread jack but I’ve been curious about the whole constant power thing. Rockford did the bdcp which confused me becuase their subs are standard 2 and 4 ohm Voice coil. Jl makes sense since Their w7’s were 1.5 ohm Voice coil. Is it for the sake of future flexibility maybe
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
The JD does ~800 watts@ 3 Ohms so I assume there would be no noticeable difference.
761
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
  • Locked
Do you have any pics with user name and date or is this at a local garage sale?????????????????
Disturbance
Disturbance
Detroit
BCotrell
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
