Im building a custom box to fit inside the rear seat and to downfire. It'll have a volume of .85 cubic feet and a 5" mounting depth. My budget is aorund 250 for amp and sub. What are your ideal setups in this situation?
not gonna get much for that little if you raise ti like 350-400 u could get a sundown sd2 10 and an audiopipe apsm1300. amps a little big but having extra power is agood thing if u learn to only use what the sub can take
sundown sd-10 150shipped 4.75in mounting depth 500rms... Get the dual 4 ohms model, wire it parallel for a 2ohm load- wish i would of gone sundown, but my jbls nice
Audio pipe APSM1300 110shipped ebay or amazon does 600rms at 2ohms- I had one, solid budget amp
That box size should actually do well for the SD10, there box rec's r the same as SA series. Ive read they like sealed boxes up to a cube or so, Just make sure you set your gain for 500rms with a dmm. With a larger box it takes less power to get louder, meaning overpowering your sub is easyer //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
