10" Budget system with amp?
it's only an extra $15 from a 10 to a 12, do you have the room for it?
as for amplifiers, you just need an amp that does at least RMS of the subwoofer.
you mentioned hifonics, so this is one that would work.
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?Source=googlebase&ProductID=16363
Dual 2 ohm Type R wired to 1 ohm
I thought of a 12" Because I did not want to take up too much room in my trunk. As far as that amp goes that is the one I am talking about but how would I wire it for a 1ohm to get the 600watt rms. Also what do 1, 2 , 4 ohms all mean, and is there any better than the other?
Wiring options.
Tell us what vehicle this is going in, we might be able to help a little more.
350 is far from the worst I've seen as far as money to be spent
Keep in mind you have to have the box and the wires too though ...
I have an amp kit already installed. This is going into a 04 neon. I just wanted something that isnt going to take up the whole trunk and also is going to sound good.
I can go up to $500 FYI
I just need help getting some bass in the back without going huge, this is my daily car
its only an extra 15$ more dollars from a 12 to a 15, do u have room for it?
Yes I have room, but is it going to be that much difference from a 10" to a 12"? I am also trying to cut down weight as my last system made my rear sag.
are you guys serious? he said a couple times he doesn't want to take up a lot of space, then he was recommended stepping up to a 15"....He stated his car in the 3rd post and then someone asked what vehicle does he have. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
he seems more worried about weight than space...and i missed that...
kevin25
kevin25
Michigan
DidUHearThat?
