10 inch SQ type subwoofer
dumple
What's in your trunk?
Who's holding out on them tens!!!!! TC / eclipse old ppi power class, maybe a type X maybe a w6, idmax..
Oooh or a soundsplinter or elemental designs, someone's gotta be holding on to an oldie but goodie
Requirements 1cuft sealed dual 4 or single 2 ohm
600-1000 rms
I'll have cash or trades
2 eclipse 10th nothing special
Jbl ms8
Jbl msa5001
Blown arc black 10
And for something really special I may be could offer up my SI MAG claw v1 d2
Subwoofer Size: 10”
RMS Power handling: 500 Watts
Peak Power handling: 1000 Watts
Recommended Box Volume: 0.47 cuft. (Sealed)
Motor Type: Custom High-Output heat dispersion
CM design
Voice Coil Type: High Temp capacity Long Throw
CM design
Voice Coil Diameter: 2”
Voice Coil Impedance: 2 ohm nominal
Xmax (one-way linear excursion): 15 mm
(More than 1.5” peak-to-peak)
Maximum Excursion: 23 mm
(about 2” peak-to-peak)
Sensitivity: 93.57 db (2.83V / 1m)
Fs (Klipple-LSI): 25.7 Hz
Qts (Klipple-LSI): 0.30
Vas (Klipple-LSI): 54.283 Liters
These pretty stringent on that rms rating ?
Can do a Dayton HO 10" Killer subs for the money.
Also have a PHD FB 10" but can not take the power you are looking to give it.
The dayton Is of mild interest but those cdt mid tweets have peaked my interest for a while now
Although the IDMAX 10 is my recommendation, I've installed Dayton HOs in 2 cars and built a pair of folded horns using them. The Daytons are certainly nice for the money, but they are not the same caliber as an IDMAX.
dumple
dumple
Philly
hrtbrk1
