10 and a 12 in a 2 chamber box?
i have 4channel amplifier and two kenwood 700watts subwoofers and a pair of pioneer 400watts speakers please tell me how i connect it to get perfect performence
Doesn't a 12 hit harder that a 10 causing no cancellation right because of different tones and hz? If they where sharing a chamber, will they still cancel? What if they are seperated?
thanks
oO
1. shared chamber... NO
if you put two different sized subs with different specs ( TS PARAMETERS ) then you will destroy one or both of your subs because it they would react differenty to the air inside the box with and when one reacts differently then it's like playing a speaker while pushing down on the cone.. you don't do it.
2. separated chamber... STILL NO.. Well i wouldn't reccomend it.
Yes the 12 would probably be louder to some extent but they still create sound waves and when sound wave clash they cancel each other out. which would create all sorts of dips and crappy sounds to your spl curve.
3. your best bet to select either the 12 or the 10 and put it in the box. but if you do the 10 and 12 together it will be like playing your door speakers like subs and running your subs at the same time ( sounds REALLY crappy ). And with the cancellation yes you WILL get cancellation if you run the two together.
Beermakesmehoppy
Beermakesmehoppy
Antioch, CA
bigred78797
AJ (ACE)
    Jun 24, 2026
AJ (ACE)
    Jun 24, 2026
