1 vs 2 woofers
BooLeaN
Hello, I am wondering if any of you have actually played with 1 vs 2 woofers of the same brand. What I am trying to find out is if you have a 1200 RMS woofer and a 1200 RMS amp, what would the difference be in POTENTIAL spl vs 1 1200 RMS woofer and 2 1200RMS woofers with the SAME 1200 RMS amp.
Basically I'm trying to figure out if it's going to be worth the extra money for 2 woofers. The other issue is that my amp is 1 ohm stable and nice woofers such as the RE HC and RE XXX are dual 2 ohm.
I have heard that doubling the woofer quantity THEORETICALLY increases the SPL by 3 dB and doubling the power increases the SPL by 3 dB. So wouldn't that mean that if you have 1 woofer with x amount of power, then add another of the same woofer, you would gain 3 db from doubling the woofers but then lose 3 db by giving it 1/2 the power as before??
Any insight would be greatly appreciated !
Thanks
So does that mean that between 1 woofer and 1200 RMS and 2 woofers and 2400 RMS there is a theoretical 6 dB increase?? Isn't that INSANE?
Also, anyone who has a single 12 or 15, feel free to post what dB you are hitting so I can get an idea. I have 2 Alpine Type R 12's ported @ 42 hz and I want Louder!!!
My problem is that I have 1200 RMS at 1 ohm, so I need something that works around there.
I hear people's vision is going blurry and mine isn't even close.
Thanks
go with a 12'' XXX and i think if you wire it parallel it will work with your amp and get the full 1200 rms. not 100%sure on that, someone else will know hopefully.
I realize that it is really dependent on box type, size, tuning frequency, quality of install, car itself, etc.
Seeing that soo many people own a single XXX or whatever, that is probably a good solution for me.
Thanks for your input thus far.
BooLeaN
BooLeaN
Canada Ontario
BooLeaN
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
