1 Sundown 2500d or 2 PG 1200.1 RSd's?
Stryker
1996 Thunderbird BOOM!
I'm currently running one Phoenix Gold 1200.1 RSD to each DD 3512e @ 2ohm's which is the lowest safe impedance with those amps, they have been known to actually be close to 1500RMS. I could switch to the aforementioned Sundown Audio 2500d and run a single amp to both subs at 1ohm. The actual on the Sundown is over 3k with the proper electrical which i do have in place already. Would it be worth switching out the PG's for the Sundown? It would mean an entire new amp rack and **** and not too sure if it's worth the effort as everything on the amp rack is all PG which is cool looking in it's own right, I have no prior experience with Sundown only what I've read here. Lemme know, I can't decide on my own....//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif seems the wattage is bout the same. Sundown is strappable tho.
I say go for the Sundown since you already bought the amp //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
lulz..... I have other plans for that in another car of mine. Gotta find a 4 channel sundown now.
Sundown is a much better sounding amp and if you happened to change subs and go .5 ohm it will take not to mention you want to throw it on a 16V elec system, well ya you can do that also //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Polo
455
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
Stryker
Stryker
Calagry, Alberta, CANADA
Safe_Cracker
    May 12, 2024
Brendon Jenness
    May 11, 2024
