1 ohm
Fender5
Should I trust my amp at 1-ohm. It says 1 ohm stable.
It is the Kenwood KAC-9103D.
500W @ 4... 900W @2... 900W
So Im assumin I can get anywhere from 900W RMS-1800W(Peak) at 1 ohm.
Im looking at the RE Audio SE subs. 2 of them. Rated at 600W RMS. And wire them to one ohm.
What do yout hink
Kenwoods are CEA-2006 compliant so it should be close on wattage. I have a kenwood kac and it hits pretty **** hard for what it is. First place at a usaci 0-600 with it anyway.
Features of Kenwood KAC9103 / KAC-9103D:
Mono subwoofer amplifier
500 watts RMS x 1 at 4 ohms (900 watts x 1 at 2 ohms)
CEA-2006 compliant
Variable low-pass filter (50-200 Hz at 24 dB per octave)
Bass boost (0-18 dB at 40 Hz )
Subsonic filter (15/25 Hz, 18 dB/octave )
Top-mounted controls
Class D design
Speaker- and preamp-level inputs
Preamp outputs
Fuse rating: 30A x 2
4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
Dimension: (WHD) 14-7/8 x 2-9/16 x 11-1/2 In.
Warranty: 1 year
NOT 1ohm stable just 2ohm.... and No it will not push 2 RE SE's very good even if your order D2 subs and wired 2ohm load... Still be way under powered..
Fender5
Fender5
Arkansas
Got_Bass89
