1 ohm wiring question
Silverado22
I have two Kicker DVC 4ohm CVR 12s and a Hifonics BXI 1206D amp, how do I wire it to get a 1 ohm load, Ive seen all the diagrams and they confuse me, the amp has two outputs for subs, I know im need to wire positve to positive and negitive to negitive but how do I do connect the subs? An actual pic will be helpful.
Wire all your positives together and all your negatives together and that'll give you a 1ohm load. As far as the connections on the amp, its a mono (one channel) amp that has two terminals for easier connection. It doesn't matter which amplifier terminals you connect the speaker wires to because they are all wired parallel internally.
no, use all the terminals, what you are gonna do is take your first sub and wire it to one terminal like this
and then after you do that, you will take your other sub,and wire it the same exact way, but to the other terminal.
what that will do is give each terminal a 2 ohm load. and both those terminals are connected together inside the amp, and combine to make it a 1 ohm load. so yes use all the terminals, and follow what i said exactly and you will be perfect. let me know if you have problems
Silverado22
Silverado22
Tennessee
blackbonnie
