1 ohm stable?
  • 2
I highly doubt it. Usually amps overheat because of user error like blocking it in or hidign it under things so heat cant escape.
It also lowers the amps efficiency and raises the current draw.
5
416
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
277
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
963
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
Nickfireblazer
Nickfireblazer
Reidsville,North Carolina
mattj
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
