hansk 10+ year member Senior VIP Member 163 0 ATL Feb 18, 2010 #1 im getting some kicker l7 15" and i was wondering if i should do the dual 4 ohm or dual 2 ohm to get a 1 ohm load.. my amp is stable 2000RMS at one ohm.. i was told to do the 4 ohm.. is that correct? Click to read more...
kr15 5,000+ posts Polluting Residentials 6,702 56 California Feb 18, 2010 #2 If you get 2 dual 4s, your options are series for a total load of 4 (8ohm each), or parallell for a total load of 1 (2ohm each) If you get 2 dual 2s, your options are series for a load of 2 (4 each) or paralell for load of .5ohm (1each)
Cabin_Pressure 10+ year member yeah, it'll do 3,216 78 USA Feb 18, 2010 #3 Dual 4 wire to 2 or 8 ohms, so two subs would wire to 1, 4 or 16 ohms. Dual 2 wire to 4 or 1 ohms, so two subs would wire to .5, 2 or 8 ohms..
TMali 10+ year member I Can Dance If I Want To 2,887 15 New Hope/Big Lake MN Feb 19, 2010 #4 dual 4 (wire to 2ohm) leaves a good option to add another dual 4 sometime if you want (wire to 1 ohm)
kr15 5,000+ posts Polluting Residentials 6,702 56 California Feb 19, 2010 #5 that is correct(8 and 16)...I failed to put those additional ohm loads as very few people have enough power to run at 16ohms or 8
OP hansk 10+ year member Senior VIP Member 163 0 ATL Feb 19, 2010 Thread Starter #6 so go with dual 4 ran in parallel to get 1ohm...right
Cabin_Pressure 10+ year member yeah, it'll do 3,216 78 USA Feb 19, 2010 #7 so go with dual 4 ran in parallel to get 1ohm...right Click to expand... Yep, if you have two subs.
OP hansk 10+ year member Senior VIP Member 163 0 ATL Feb 19, 2010 Thread Starter #8 Yep, if you have two subs. Click to expand... ya im gettng to i was just trying to figure b/w 4ohm and 2 ohm
TMali 10+ year member I Can Dance If I Want To 2,887 15 New Hope/Big Lake MN Feb 19, 2010 #9 ya im gettng to i was just trying to figure b/w 4ohm and 2 ohm Click to expand... oh, yes go with two dvc 4 l7's then Rockford Fosgate® - Woofer WiringWizard 1
