1 BNIB Audiopipe AP1800
S.B.C.
Brand New In Box - Was going to run 14, now only running 12.
These are $195 shipped new on Ebay. Save a few dollars.
$175 shipped. Paypal Preffered.
No Trades.
Will be shipped Fed Ex
Bass Boost Control
1 ohm load stable
overload protection
overheat protection
variable low pass electronic crossover
variable subsonic filter
built-in variable phase shift
master/slave allows 2 amps to be linked for maximum power output.
distortions:
signal to noise ratio: 70dB
input level: 0.2-5v
bass boost frequency: 30-80hz
low pass filter: 40-180hz
subsonic filter: 5-50hz
frequency response: 8-180hz
750 x 1 RMS @ 4 Ohms
1100 x 1 RMS @ 2 Ohms
1800 x 1 RMS @ 1 Ohms
Dimensions (WxLxH): 7" x 2.5" x 30
whats the biz on these amps? im not familiar with them @ all but i keep seeing good comments about them considering the price of them.. seems too cheap in price for something thats supposed to be quality. how do they sound and do they do anywhere close to the power that they say they do?
ill vouch for these amps they are not bad at all for the price im running 2 of them on 2 12's with like no testing on it and did a 149.8 db so for the price a great amp
---------- Post added at 12:15 PM ---------- Previous post was at 12:14 PM ----------
too bad u wont do trades id be willing to trade a pretty much brand new Sanyhandycam for it only used 2twice
I run the AP10001d on my IA Death Row 15, and it doesn't do bad at all. I'd love to have this 1800, but no cash.
To OP, does this one have 1/0 inputs or 4 gauge?
Kef
According to the AP site it has 4 gauge inputs. What I would recommend is doing a run of like some Knu 1/0 CCA or some OFC welding cable, and then just distro right before the amp down to some OFC 4g.
They do rated power
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Kef
4ga
This isnt needed..
You will not get close to the limits of a true 4 gauge wire within length of car audio on this power size amp. SO its nothing to worry but overkill is better if you got the money. If anyone has actually clamped their amps, you would know.
OP, you said you had 14 but only running 12. SO you actually have two for sale? Im interested in both if you can give me a good deal. Located in KY.
You will get close to the limits of a true 4 gauge wire within length of car audio on this power size amp. SO its nothing to worry but overkill is better if you got the money. If anyone has actually clamped their amps, you would know.
AP's have been clamped for putting out rated and then some, and doing a 10ft run of some CCA 1/0 rather than some 4g is gonna be like what, $5-10 more? The only reason I say to do 1/0 is cause if you push a wire to its limits for a lengthy period of time you run the risk of a fire hazard..
1800w is pushing the limits for 4 gauge and it doesn't hurt to do a run of some 1/0 before hand.
Not if it's ran off a batteries in the back.. And if your running off the front batt only, then you dont need this amp.
SOLD
S.B.C.
S.B.C.
IL
Coolwazabi
    Jun 20, 2026
    Jun 20, 2026
