(1) American bass 500.1 (2) Sundown Audio Saz-2000d (1) Orion XTR 2250 "the beast"
BumpinKota
Both american bass amps are 9/10 cosmetically 10/10 mechanically
The sundown amps are both 8/10 cosmetically (missing set screw for a power on one of them) and 10/10 mechanically
The Orion 2250 is 9/10 cosmetically 10/10 mechanically
AB 500.1:
1 x 1400W @ 4 ohms (14.4V - 1% THD)
1 x 2650W @ 2 ohms (14.4V - 1% THD)
1 x 3200W @ 1 ohm (12V - 1% THD)
1 x 4700W @ 1 ohm (14.4V - 1% THD)
1 x 5600W @ 1 ohm (16V - 1% THD)
1 x 7100W @ 1 ohm (18V - 1% THD)
Signal to Noise : 85dB
Damping Factor : 200
Efficiency : 75%
Sundown 2k:
Digital Class-D Linkable Mono Block Amplifier
Double Sided Through Hole Epoxy PCB
1 Ohm Stability
Daisy-Chain Through Output RCA
Efficiency : 86% @ 4 ohm, at 100Hz
24dB/Oct Variable Crossover
Multi-Way Protection Circuitry
(Thermal/Over Current/Speaker Short/Speaker DC Protection)
RCA Line Input and Master Output
24dB Octave Crossover Slope
24dB Octave Variable Subsonic Crossover Slope
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Zero(0) Gauge Power Supply Connectors
Tested Voltage & THD : 14.4V & Less than 1% THD
Operating Voltage : DC 10V~18V
Wired Remote Controller
MSRP $899 USD
Rated power output
----RMS power, 2 ohm linkable/dual mono
4000W x 1CH ----RMS power, 1 ohm mono
2000W x 1CH ----RMS power, 2 ohm mono 1000W x 1CH ----RMS power, 4 ohm mono
500W x 1CH Signal to Noise Ratio >90dB Low pass frequency crossover 35Hz~300Hz Subsonic filter 10Hz~60Hz Bass boost @ 45Hz 0~6dB Phase shift control 0~180 degree Frequency response 10Hz~350Hz (+/- 1dB) T.H.D @ 4 ohm
Orion XTR 2250:
Power: 250W x 2ch @ 4ohm on 12V battery [rated]
500W x 2ch @ 2ohm on 12V battery [rated]
1000W x 1ch @ 4ohm on 12V battery [rated]
THD: 0.03%
Slew Rate: >30 Volts per microseccond
Output Damping: >200
S/N w/balanced input: 100dB
Power Bandwidth: 6Hz to 1000kHz +/- 5dB
Full Power: 120A
Price: ALL ARE OBO!
American bass 500.1 $750 each plus shipping
Sundown 2000 $400 each plus shipping
Orion XTR 2250 $400 plus shipping
BumpinKota
BumpinKota
Cleveland, OH
BumpinKota
