1.5kw to 3kw
Question: I need to know the best battery upgrade for my setup
Setup: 05 trailblazer.. 150a alt.. stock battery under hood... yellow top in rear... 1.5kw (us amps ax series)... 1 18" re xxx.
I want to eventually move on from 1.5kw to 3kw. This sub is a ****ing monster on 1.5 i can't imagine it at 3kw, double the power. In its sealed box some of the songs it drops on... my GOD.
..anyway enough of the sub-*** but on full power (alpine head unit goes to about volume 20-25 before distortion through components begins)...
i can listen fine at 1-10 (volume), but when i hit 15 and 20-25, it BOOMS for a minute, then it seems as if the "umph" it had when i first turned it up was gone, and the headlights start dimming dramatically.
now i obviously know what the problem is, my electrical needs upgraded.
I was thinking that if i slowly build it up, i can eventually swap amps (us amps ax-1500de to sundown saz-3000)
Alternator: EA, Iraggi.... i've been hearing so many conflicting reports about these alternators I really honestly don't know what to believe. Mean Green has never responded back to me for a quote. Any recommendations or support for either company here?
Battery: Plan - take current yellow top and replace stock battery under hood with that. With no battery in rear, i was considering the Kinetik series, like the hc2400, etc. ANY other brand recommendations? Also, what size battery would i need or would be sufficient with a YT under the hood on 3kw (and NO alt upgrade?)
If you want to upgrade from 1.5kw to 3kw I would recommend moving the Yellow top to the front and then picking up a pair of Kinetik HC2400s for the back. However, that may not be enough.
I have a trailblazer as well. I run an Autotek MM3000.1d @ 1ohm on two optima red tops just fine.. voltage only drops to 12.xx volts @ idle and stays around high 13's low 14's when cruising around.
Kinetik HC2400:
Weight: 69 lbs.
Ah: 128
Amps: 2600 (cold cranking or max?)
Dimensions: 13" x 6.7" x 8.5"
Suggested Retail: $449.00
Powermaster PWM-D3100:
weight: 77lbs
coldcranking amps: 1,200 (max 3200)
retail: $299
which one?
Kinetik HC2400:
Weight: 69 lbs.
Ah: 128
weight: 77lbs
retail: $299
which one?
the 2600A rating is not a CCA rating. i have never seen a battery that high, ever.
for 3 k, i would just get a nice 220+ amp ho alt, a nice big battery up front, and 2 g31 dekas in the back (or any other group 31 battery).
my mean green runs just fine, although the rear bearing is a teeny bit noisy now. i havent gotten a chance to pull the bearing yet, and since its causing no problems, besides a slight whirling noise, i dont even know when ill change it. simple fix, but thats the only problem ive had with it. powerful as well, and does a true 200 hot amps. (cold is about 220, so comparing it to 99% of other alt companies alts, use the cold rating)
BreakingBad
Banned
BreakingBad
pittsburgh
BreakingBad
vegang
vegang
