1.2 ohm subs
Like this for a 1.2 ohm load
unless they are single voice coil
then all you can do is wire to 2.4 ohm or 0.6 ohm.
Hifonics 2100d amp subs are lanzar opti. They are on amazon.ca with free delivery. Free delivery to Canada is huge there is a ton of better options but then I have to pay shipping to cad not cheap. They are dual 1.2 ohm subs lanzar
Yeah based on subs and amp I would not recommend running at .6 Do you have any electrical mods done yet? What sized power wire? I'd recommend 1/0 power and big 3. If you don't know what the big 3 is a simple search will tell you. You may also want to look into a volt meter mounted up front and wires run to the amps power input to help keep an eye on it. If voltage becomes an issue a second fused battery in the back will help some.
I hope my electrical will be enough it's been slow project money is tight. Up front xs power d3400 big 3 and mechmen ho alt.
Sent from my SM-G920W8 using Tapatalk
Trying to figure out pics from tap talk
Anybody have any input on theses are they a good splq. Sub .They are on amazon canada free shipping 1.3 ohms . What ohms can they be wired two . Sorry for asking same question twice but I noticed these are a difrent ohm subs as mentioned earlier
Thank guys for all the help awesome
Anything with a . after a number, it's always gonna be that ohm no matter what. So you you have 1.3 or 1.2 it's 1 in the real world, even if the DMM told ya diff and it matches the 1.3 anyway.
Same with other impedance subs. Mine are d4 ohm each....but prob measured 4.3 or so.
rp69
rp69
calgary alberta
Boomin_tahoe
