1-2 OHM Load amp **Newb Question**
you would need a sub that is a single 2 ohm voice coil, or a dual 4 ohm voice coil to get a final load of 2 ohms.
the reason for the sub change is your sub will have either a 4 ohm load, or a 1 ohm load depending on how you wire it.
the amp does 1500 watts x1 @ 2 ohms. so youd be getting the full amount of rated power out of the amp, theoretically speaking, at 2 ohm....but the amp isnt rated to be stable at a 1 ohm
Is there a certain way to hook up this certain amp to the sub. Like a diagram
*Edit* so i need a 1ohm amp right?
1500 x 1
It is unstable at 1 ohm.
Get a sub that does 2 or 4 ohms.
To wire the sub to the amp to a 4 ohm load, you need to wire it in series.
You will only get 750 watts out of the amp if you do it that way, but that would be MUCH better than wiring the sub up to 1 ohm, causing the amp to go ka-poof.
Or you could just get a new amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
To all you motha****as that juss can't tell
I'm a Pisces but I'd rather be a killa whale
Attitude juss like a ruthless Cuban coke dealer
In Miami, nothin but the money and the power
A deadly mix at 6 foot 6 I'm sorta like a tower
Or a tanker, a motha****in Iraq tanker
To all you motha****as that juss can't tellI'm a Pisces but I'd rather be a killa whale
what a badazz
what a badazz
I thought the OP would appreciate someone else outside of the Bay Area knowing a little Nickatina. But you're very cool yourself, aren't you? //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
^^^ haha //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif that's what im talkin bout. ^^^
Nickatina comes hard wit the Cocaine Raps...
Where you from?
Kastlez_
Kastlez_
Bay Area, CA
dman4486
