1 18 inch kicker solo vs. 6 kicker solo-baric l5
chevyboy3001
I no this may not be in the right section, but I was wondering what you guys think. I got 6 12 inch solo-baric l5's in a 85 caprice being pushed with a hifonics bxi 2006 at 1.33 ohms. The shit is loud. But do you guys think if I got 1 18 inch solo x being pushed by the same amp, would it be louder or just keep what I got.
take the 6 twelves over the eighteen, oh and you might wanna consider another amp because that hifonics probably only put out near 1800 watts at 1 ohm.
The rms on the Solo x 18 is 5000 watts so that wouldnt work.
The rms on you 6 twelves together would be 3600 watts so either way your underpowering and your hole system is gonna be a waste of time and money. So if your gonna use that amp your gonna need 2 minimum for either setup period.
and im gonna guess he doesn't have the electrical upgrades for that either...this is what you get when fully unknowledgable people go into a car audio shop with a pocket full of cash.
I got the proper electrical upgrades, was just wondering wht you guys thought on the subject. Thanks for the input.
x2.
I have a feeling that this setup is not working near its potential. 6 12's in the trunk (assuming they're not walled) is too many subs to fit in that little area. I'm sure they're being choked. I would do a single 15, build multiple boxes with different firing options and use some aeroports.
x2.
x2...//content.invisioncic.com/y282845/emoticons/graduate.gif.d982460be9f153bb54e5d4cb744f6ae8.gif
i think that somone with a pair of 12's, the right power, and the right box could get louder than 6 12's choked off in a small box with only 1~2kw.
if i were you. id take out 2 of those 12's and double the power and make a new box.
i bet it might get a little louder.
its about the install, not how much cone area and watts you feed it. DESIGN a box. do some TESTING with it. apply the correct amount of power and you will see results.
how is every noob that comes on here wanting to put in a 5k watt system always has the electrical to back it up, but then they asked the most stupid questions which more than likely proves they dont have the right electrical.
chevyboy3001
chevyboy3001
jacksonville,fl
lookitsjim23
