1,100 dollars to work with.
brenTgrillzem
Alright I recently purchased a set of Hertz HSK 165's and I'm trying to figure out the rest...
I was thinking
Alpine 9887 also the Sundown 100.4D to complete my front stage with the HSK's.. running active.
I have a single cab truck, 98 dodge ram, need to get some measurments first but..
I was wondering should I go with the second skin damplifier pro door pack for 60$ and then go with 40 sq ft of regular second skin for 98$ or go with 62.5 sq ft of RAAMmat for 118$?
Or go with 36.5 sq ft of second skin pro for 160$.
Also need to know about all the wiring and shit too.
Get all Knukonceptz wiring, depending on your amp get either 4 Ga or 1/0 Ga, get your RCA's, fuses and all that crap from them too
Get the 62.5 sq ft od Raammat
I guess you are going for an SQ set up because of the Hertz and going active. If so i will look at some good subs you can try.
Yeah, so just the 62.5 of raammat, or with the SS pro door pack?
Later on down the road I was thinking of doing sundown 1200/1500 with a 12'' Fi BL upgrading all the electrical and doing the big 3..
100.4D to run the front components? Isn't that a lot? Why not the 125.2?
In this case, you don't NEED to get the 9887 to go active with this. As I understand it, the 100.4D (and 125.2) can go active for you, right?
Wow.
That is probly the sweetest 'stang I've seen (your sig)
If, I were to go for SQL and not go for the the punchy/tight bass what should I look at? Again this will be down the road..
For now I'm just trying to get suggestions for finishing my front stage...
I need the 100.4 instead of the 125.2 because I can use the x-overs to run active correct?
Wow.
Hey thanks! Some better pics in this thread:
http://www.caraudio.com/forum/showthread.php?t=371780
(page 2)
The Hertz are rated for 125w RMS, so the 125.2 would be perfect. Even still, the 125.2 is underrated. I think I read somewhere that it was putting down closer to 140w each channel at 4 ohm.
And the 125.2 has the improved crossover as well. Pretty sure you can go active with the on-board crossover. Maybe Sundownz (the owner of Sundown Audio) can chime in here? Maybe PM him.
brenTgrillzem
brenTgrillzem
Flo-Rida
brenTgrillzem
