1/0 ring terminals
I may end up using the Knu oversized CCA. Or something similar if I can find some soon.
If you look at copper terminals then you will want 2/0 more then likely. The wire will fit much better and it will be far easier to crimp or solder as you won't need to trim the wire down or anything.
The lugs I posted a pic of on here are 2/0 on "1/0" wire.
Beatin'
Beatin'
MI
parasite
