1/0 and CUSTOM BUSS BARS
outsideshot23
OKC
Lots of 1/0 and custom buss bars
100% OFC scosche efx flux and Knu Kolossus. They are nearly identical wire you can see from pics below. 5145 Strands!!!. I have 6 runs of silver flux(15-16ft). 3 runs of black flux(~7ft). and 2 runs of blue Kolossus(~4ft). All wire has a ring terminal already on one end. Wire is in excellent shape. No knicks no cuts and very easy to run. Just some grease here and there from running it over the frame into the bed. Also have tons of short runs 2-4ft of silver and black flux
Buss bars were custom made for my huge battery rack but i will cut them down to sing, double, etc.. I have enough to do 16 batts. Each batt block will come with 6 predrilled and tapped holes. Holes are drilled all the way through so wire can be run from front or back and drilled out to 2/0 so it is very easy to get 1/0 in and out. Allen head screw downs on heach hole. So one batt = 2 aluminum blocks (12 holes) 6 each. So lots of runs can be made from alt to block to amp and to grounds. These look awesome as you can see from the pics.
2.50/ft on all wire. Its very thick and VERY flexible. 100%ofc
25$ per batt (includes one for pos post and neg post, each post has 6 1/0 holes drilled and tapped)
can be cheaper for multiple batts
5$ shipping and fees..unless you buy alot i will just pay for it.
pms sent. Also i forgot to mention i had the bars built so i had 1/8" of gap between my batts so they would not rub together. So these should fit ANY battery.. will fit g31 batts for sure and slightly bigger
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
5K
  • Locked
15" Custom Sub Dual 1 ohm I've had it running off 2000rms in my daily. I'll include the box if you're in SoCal for pick up, Dimensions are...
outsideshot23
outsideshot23
OKC
Silver-N-Black
